Buff A Satin MexiMartin to High Gloss?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10137&t=51579
Author:  Kbore [ Fri Feb 08, 2019 5:06 pm ]
Post subject:  Buff A Satin MexiMartin to High Gloss?
Could a Mexican Martin Custom X model Dread be buffed out to a gloss, by polish sand and buff?
Author:  Freeman [ Fri Feb 08, 2019 8:11 pm ]
Post subject:  Re: Buff A Satin MexiMartin to High Gloss?
X model Martins have a HPL back and sides, spruce top. At least the one that I just repaired did. The finish on the top looks pretty thin, I don't know if there is enough there to buff, I rather doubt it. The back has a mahogany looking wood grain in the outer layer - I don't think there is any finish at all. Can it be buffed? I don't know, probably wouldn't hurt to try.
The one I worked on had been dropped and the back to side seam had been split. A piece of the back had been broken out - I was able to put it all back together with CA. I lightly sanded some of the edges of the broken piece and got a white line indicating that I had sanded thru the outer "wood" layer. I did some drop filling with CA, scraped back level and went over the repair with 0000 steel wool to restore the satin finish.
Author:  B. Howard [ Sat Feb 09, 2019 6:38 am ]
There is no finish on those Formica guitars.
The white line was the bottom of the plastic laminate on top of the phenolic base. It's basically kitchen counter material.....
